This part was model using 2D sketch in the video. Do you have any idea of modeling this using 3D sketch only. I think using 3D sketch is simple. I tried but unable to proceed.
Maha Nadarasa, I'm not sure why you think this has to be done using a 3D sketch but here one way to do it. I'm sure some will think its not the best way but it meets the requirement of having just one 3D sketch.
Sorry, i can't access the file now, because of the "Outbreak" confinement.
But i think Mark Dougall find the same solution like, maybe he can give his file.
except i begin create tree with 3d sketch, and use some "temporary 2d plane" inside,
to close the path, you may need to "cheat" a little, because
if you add "equal length" to every line, you get an error to the end, while closing the path itself.
also the cheat of not using a dim "XX" at one place, and use the cheat of "XX.001" to avoid geometric failure.
and i only used a 2d sketch for the Sweep, because i used a "temporary 2d plane" (from the 3d sketch) to create the 2d shape sketch.
and to finish, in the "Sweep" option panel, i activated "Merge Tangent Faces"
Impossible make in one operation. Its the same as Mobius Ribbon.
But no one can forbidden to try you. Some are still fighting Perpetuum Mobile.
