Solidworks Visualize import failed
Question asked by Rouanet Rouanet,Gaetan on Mar 12, 2020
Hello Everyone!
I need to create an animation with visualize and I have an assembly with a motion study. When i try to export it with Advanced Export from Solidworks 2019 SP3 to Visualize 2019 SP3 i get an error (Import failed. For more information refer to log file). If I try with the simple export everything is fine but obviously I loose the  motion study.
Attached there's a log of the error.
Here is a part of the log with, i think, the problem that occur :
"81493578 INFO Main Application Diagnostics.Log: Pausing because lost focus
81496943 INFO Main Application Diagnostics.Log: Unpausing because got focus (or because AutoPauseRendering got turned off)
81497803 INFO Main Application Diagnostics.Log: Pausing because lost focus
81507650 ERROR Main Application Manage.DataModelImporter: Importer exception:
System.ArgumentOutOfRangeException: L'index était hors limites. Il ne doit pas être négatif et doit être inférieur à la taille de la collection.
Nom du paramètre : index
à System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
à Bunkspeed.Common.DataModel.DataModels.BakedAnimationData.GetSampleByIndex(Int32 sampleIndex)
à Bunkspeed.Common.DataModel.Asset.BakedAnimationDataLoadSave.Save(Stream stream, IBakedAnimationData bakedAnimationData)
à Bunkspeed.Common.DataModel.DataStore.DirectoryBasedAssetStore.UpdateValue(IAssetHandle assetHandle, Object value)
à Bunkspeed.Common.DataModel.Manage.ProjectAssetAcquisitionManager.DoAcquireAssets(IImportSession importSession, IEnumerable`1 assetHandleDataModels, Boolean allowImport, IAssetAcquisitionStrategy acquisitionStrategy, IProgressState progressState)
à Bunkspeed.Common.DataModel.Manage.ProjectAssetAcquisitionManager.BatchAcquireAssets(IImportSession importSession, IEnumerable`1 assetHandleDataModels, IAssetAcquisitionStrategy acquisitionStrategy, IProgressState progressState)
à Bunkspeed.Common.Import.Manage.DataModelImporter.ImportAllAssets(IImportSession importSession, IEnumerable`1 importedItems, IProgressState progressState)
à Bunkspeed.Common.Import.Manage.DataModelImporter.ImportModels(DataModelImporterChoices dataModelImporterOptions)
à Bunkspeed.Common.Import.Manage.DataModelImporter.<>c__DisplayClass44_0.<Import>b__0()
à Bunkspeed.Rendering.ApplicationLayer.LongJobs.LongJobHelper.ThreadStart()
81507651 INFO Main Application Notifications.Notifications: <log4net.Error>Exception during StringFormat: L'index (de base zéro) doit être supérieur ou égal à zéro et inférieur à la taille de la liste des arguments. <format>L'importation a échoué. Veuillez consulter le {0} pour plus de détails. le fichier journal OK Bunkspeed.Common.Interfaces.UI.NotificationTypeBase</format><args>{}</args></log4net.Error> "
If someone have an idea of what the problem could be don't hesitate.
Thank you all
