We are trying to loop through all components of a pattern (chain pattern) in order to suppress every 5th (or rather n-th) component of that pattern.
Is it possible to loop through a selected pattern?
Thanks for your response.
The line "Set FeatureData = swPattern.GetDefinition" throwns an error for me if I use it with a linear pattern.
The actual usecase is with chain patterns inside assemblies. I modified the data type to "Dim FeatureData As SldWorks.ChainPatternFeatureData" but the method of skipping / suppressing single features seems different for chain patterns. FeatureData.SkippedItemArray = swSkippedPattern does not work
Also we would like to skip every 5th element, not only exactly the fifth.
For Chain pattern:
Option Explicit
Dim swPattern As SldWorks.Feature
Dim swSubFeat As SldWorks.Feature
Dim boolstatus As Boolean
Dim i As Long
Set swModel = swApp.ActiveDoc
'boolstatus = swModel.Extension.SelectByID2("ChainPattern1", "COMPPATTERN", 0, 0, 0, False, 0, Nothing, 0)
Set swPattern = swSelMgr.GetSelectedObject6(1, -1)
If swPattern Is Nothing Then
MsgBox "Can't find pattern"
Exit Sub
If FeatureData Is Nothing Then
MsgBox "Can't find pattern data"
Exit Sub
End Ifi = 0
swModel.ClearSelection2 True
Set swSubFeat = swPattern.GetFirstSubFeature
While Not swSubFeat Is Nothing
i = i + 1
If i Mod 5 = 0 Then
Set swComp = swSubFeat.GetSpecificFeature2
swComp.Select4 True, Nothing, False
Set swSubFeat = swSubFeat.GetNextSubFeature
Wend
swModel.EditSuppress2
Hello. Select a Linear Pattern with at last 5 components, then run this macro:
It will skip the 5th instance.
