Can someone explain fit text? I can't seem to get it to work they way I think it should.
Filling out a title block, I want it to fill the block(space) but not go over.
Why does the text go outside the bounder I give it. I did hit the fit icon.
PS this is a attributed block, if that makes a difference.
Thanks in advance!
Yeah, this doesn't work the way that you would expect. It physically stretches the text. Which is what no one wants.
What I would do is use either the word wrap function inside the manager of the text properties, or grab the red dots on the border when you are editing the text to stretch them to the limits that you want. Then the text will simply word wrap when you want it, but will not fill it if it is shorter.
