I am working on a label for my company to be used on various size product. We make a part model for our label that we use in assembly for different parts. Is there any way I can have one model and scale it while in assembly as per my need so that I do not have to make different label model for different sizes?
Set up a "master sketch" as the first item in the feature tree. Sketch will be a centered rectangle with 2 dimensions (width & height).
Design your label to be linked to the master sketch. In other words, no dimensions needed!
Name this configuration "Size1".
Add a new configuration every time you need a new size. Just edit master sketch dimensions.
In the assembly, just select the appropriate "SizeX" configuration.
