I'm looking for the setting in SW 2020 that would keep the placement face when placing hole wizard holes from going totally transparent as if they're not even a face there. The 2 designers plus myself have the same Dell M6800 with the quadro K3100m video display & same R418 version driver. When I place a hole wizard hole, the placement face just changes color, when one of the others places it his goes to about a 50% transparent but the 3rd one the face goes totally transparent & he's not liking that face. Tried comparing settings & they seem to be the same but there's got to be a setting I'm missing. Any one have any ideas or what to look for. Thanks.
You should take a look at how each of you is placing the points. Are you using a 3D or 2D sketch. When I use a 3D sketch the face changes to a solid color. When I use a 2D sketch I get a transparent color. The only time I see no color is if I go back to the type tab then re-select the positions tab.
