we have few models that need separate drawings for all the different model configurations. For just few of them it's not a problem but few models have over 150 different configurations and generating them all by hand is waste of resources...
I found this macro that will go trough the given drawing and save a new drawing with the given configuration active. This works quite nicely. Problem is the output filename, if the part and first drawing names are "1234-001 - Test piece.sldprt" and "1234-001 - Test piece.slddrw" it will output the new drawing as "1234-001 - Test piece - Sheet1 - Configuration name.slddrw".
I've tried to modify that macro as follows to get the drawing numbers. This works nice if the DwgNo property is already in the drawing properties but how to get it read the DwgNo from the Configuration Specific properties of the part? The drawing template calls DwgNo as $PRPSHEET from the part and it updates correctly.
'Created by Artem Taturevych (Intercad, Australia)
'http://intercad.com.au/
'Disclaimer: The API examples are provided as is and should be used as reference only.
'You may redistribute it and/or modify it on the condition that this header is retained.
'In no event shall Intercad be liable for any types of damages whatsoever
'(including without limitation, damages from the loss of use, data, profits, or business)
'arising out of the uses of this information, applications, or services.
Const OUTPUT_FOLDER = "C:\Out\"
Dim swCustPropMgr As SldWorks.CustomPropertyManager
Dim Piirustusnumero As String
Set swModel = swApp.ActiveDoc
Set swDraw = swModel
Dim i As Integer
Dim vConfs As Variant
Dim swView As SldWorks.View
Set swView = swDraw.GetFirstView().GetNextView
Dim swRefModel As SldWorks.ModelDoc2
Set swRefModel = swView.ReferencedDocument
vConfs = swRefModel.GetConfigurationNames
For i = 0 To UBound(vConfs)
Dim confName As String
confName = vConfs(i)
GetDwgNo confName
ProcessViews confName
swModel.ForceRebuild3 False
swModel.Extension.SaveAs OUTPUT_FOLDER + DwgNo + " - " + confName + ".slddrw", swSaveAsVersion_e.swSaveAsCurrentVersion, swSaveAsOptions_e.swSaveAsOptions_Copy, Nothing, 0, 0
Next
MsgBox "Completed"
Sub ProcessViews(confName As String)
Dim i As Integer
Dim vSheets As Variant
vSheets = swDraw.GetViews
For i = 0 To UBound(vSheets)
Dim j As Integer
Dim vViews As Variant
vViews = vSheets(i)
For j = 0 To UBound(vViews)
Set swView = vViews(j)
swView.ReferencedConfiguration = confName
Next
Next
Sub GetDwgNo(confName As String)
Set swCustPropMgr = swModel.Extension.CustomPropertyManager("")
Dim valOut As String
Dim evalValOut As String
swCustPropMgr.Get3 "DwgNo", False, valOut, evalValOut
DwgNo = evalValOut
