Macro: Create configs of range of sizes - loop problems
Question asked by Ben Richardson on Mar 5, 2020
Latest reply on Mar 5, 2020 by Ben Richardson
I am trying to create a macro that will generate configurations of different sizes from 15mm up to 90mm in steps of 5mm, which also changes the scaling dimension (D1@SKetch1) to the same value as the config name. I have gotten this to work creating a single configuration but now that I have introduced a loop to create them all its appears to be in an endless loop. Im also not sure if integer is the right variable type, decimal is giving errors.
Here is the code:
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Dim scaleDimension As Object
Dim size As Integer
Set Part = swApp.ActiveDoc
size = 0.015 'set lowest size for D1@Sketch1 - 15mm
While size <> 0.09 'until size = 90mm
    boolstatus = Part.AddConfiguration2(size & "mm", "", "", True, False, False, True, 256) 'create configuration
    boolstatus = Part.Extension.SelectByID2("Boss-Extrude1", "BODYFEATURE", 0, 0, 0, False, 0, Nothing, 0) 'select boss extrude 1
    Part.FeatEdit 'edit sketch
    Set scaleDimension = Part.Parameter("D1@Sketch1") 'Change scaling dimension to config name value
    scaleDimension.SystemValue = size 'input value
    Part.SketchManager.InsertSketch True 'close sketch
    size = size + 0.005
Wend
Any help appreciated!
