Good morning,
i'm using SolidWorks for quite a long time. But i have never needed to create complex surfaces.
Now i need to create a surface that will act as slide for a cylinder.
The idea is the cylinder is falling from the top onto the surface. Based on gradient of the surface the cylinder is turned for 90° and is sliding down/out.
Attached you find my current surface. You will directly see that the front right "corner" of the surface is not closed. Of course it needs to be closed to work. I have tried to close the surface by using different sketches.
But I'm not really come forward and i guess the way i used to achieve the current state is not the best.
For better unterstanding i have also attached a screenshot showing the (red) cylinder, that is falling from the top onto the surface.
Does anyone have suggestions or ideas how to create the surface in a better way?
Thank you very much!
Best regards
Matthias
