I'm having trouble with the cyclic symmetry fixture. In my nonlinear analysis the 60 degree sections are not being bonded across the symmetry planes. I'm using the exact setup as my initial linear (copied study to nonlinear) analysis and did not have this issue.
Static Linear Result:
Static Nonlinear Result:
Any thoughts?
Edit: I tested the regular symmetry fixture and that works fine for nonlinear. That's better than nothing but I'm not sure why the cyclic one doesn't work for me. I'm using SolidWork's 2017 if that helps.
Hi Jordan,
If you want to attach a .ZIP of your assembly and parts onto this thread we could test your setup in later versions and see if this is something that is not fixed just by an upgrade.
