I am working on simulating the heat transfer in a assembly that I have made, each component with different heat transfer coefficients. I have two heat sources, one at 400 C and the other at 2950 C. The main part of the assembly seems to only be affected by the 400 C heat source. The part with the 2950 C heat source doesn't effect the rest of the assembly for whatever reason. I have messed around with bonded component contacts and mesh size but nothing I do helps.
Thank you
Hi Tevin,
The picture doesn't give enough of the story here to give you any kind of definite answer. You may want to attach a .ZIP of your files to this thread so we can give you more specific answers.
