is there a comand line with attributes to convert slddrw to pdf with either current sheet or custom sheet/sheets?
Is there also a way to use already opened solidworks?
No.
You need a macro. There are approximately 67 billion "save to PDF" macros. "#TASK" seems pretty popular. Do a search and take your pick.
Here is another option which doesn't even require SOLIDWORKS: Batch export SOLIDWORKS files to PDF via eDrawings API (without SOLIDWORKS)
So why is the answer no?
Run SOLIDWORKS macro automatically on application start
