I'm trying to create a front facing plane rotated at 30 degrees, standing 90 degrees to and on top of a top plane.
I'm not finding any instruction in MySW that would explain something close to this.
Anyone have the answer ?
Thank you, Frank
Thank you, Frank
I'll explain this another way. I have a bottom rectangle, I'm going to put another smaller rectangle on top of it. But the top rectangle is going to be extruded from face to back from a front facing plane. Not from bottom to top. And I have no reference geometry to pull the front plane off of. And the front facing plane has to be 30 degrees of the face of the bottom rectangle. I've tried making it parallel to screen but I can't control the angle. The plane has to be controlled.
F. Leatin wrote:
... I have no reference geometry to pull the front plane off of. ..............The plane has to be controlled.
So why not create reference geometry?
Create a 3D Line sketch in construction lines. With this you'll be able to control the location, rotation and translation of the plane you'll make. Also don't forget that if you define a plane by means of a triangle you can even lock down what side of the plane is back or front.
Post some images or your file.
F. Leatin - I agree with the comments, You need to create your own geometry with sketches and add a plane from that geometry. Planes can be a real challenge..
Is it a homework question that set rules of not using reference geometry and there for prehibits you from doing any of our suggestions ?
If any of the help provided works for you then mark the correct answer.
If it didn't then you should elaborate in more detail what it is that you want to get and why the supplied proposals don't work for you or if it's just you wanting us to do your homework.
On the drawing you showed us the instruction is : "All holes are through"
English isn't my native language but I would parse that as meaning that the holes are simple straight holes and not as 'through all'.
If the later would be valid then you're model is correct but the isometric view on the drawing you showed us is wrong because it too would show the hole through the base of the slanted element on top.
