Nick Gvk
Switching versions problems
Discussion created by Nick Gvk on Feb 29, 2020
Latest reply on Mar 4, 2020 by Nick Gvk
so i just changed my version from 2014 to 2016
and im running into 2 problems that seriously interupt my whole workflow
first one being :
when in 2014 pressing the spacebar it would put u in a isometric view and show the view selector cube
in 2016 it zoomes out and gives me the selector cube ( not putting me into isometric view)
this topic solved the question not the problem
https://forum.solidworks.com/thread/97055
for me since i have been using 2014 for 5 years its a downgrade going to 2016
been a while since i done macro's so i was trying to solve this by just making a macro calling the isometric view and then call the view selector cube , then set the macro to the spacebar as a shortcut
here is what i have :
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Dim instance As IModelView
Dim value As Object
Set swApp = _
Application.SldWorks
Set Part = swApp.ActiveDoc
Dim myModelView As Object
Part.ShowNamedView2 "*Isometric", 7
Part.ViewZoomtofit2
this is the view i want each time i press the spacebar going into isometric and have this cube show up
second when creating a new sketch the first time i get this temp view
but when creating a second sketch in the same file it does not prompt this visual
i tried going true the setting but im not able to find this
anyone know where to find this or do i now have to go true the dropdown menu every single time ?
these 2 changes take away the speed i have gotten used to
might find more isue's but sofar its been smooth sailing other then those 2
i dont like the new icons but i gues it cant be helped more then going to classic mode
ill take that change because i can now use the dark theme
