Hi Guys,
I'm trying to dimension a vent feature in a sheetmetal part but it wont dimension. All other dimensions in drawing are ok except the vent feature, that is fully dimensioned in the model , I have tried to import these dimensions into the drawing using Annotate>Model items drawing mode but it is only adding 2 dims.
I have included two screenshots, one of the model with dims and the other of the error I get in drawing mode.
Can you help?
Lee
Usually that message means you are trying to detail a spline. If that vent is on a different plane then the plane that you are viewing, then it is a spline. You will need to make a projection view looking dead on at the vent, then you will be able to detail it.
