1 Reply Latest reply on May 7, 2009 6:30 PM by Eddie Cyganik
    Shaded view with hidden lines?
    Corey Wallace
      Is it possible to show hidden lines in a shaded view?
        • Shaded view with hidden lines?
          Eddie Cyganik
          Corey,
          The best you are going to do is in model mode where you can set "Edge display in shaded with edges display" to "wireframe".
          See Tools - Options - System Options - Display/Selection
          or, for the same effect,
          Set your part model color to a transparency level that allow some see-through. It has the same effect as the bove method. The difference is, you need to use this last method if you are creating a shaded drawing view. If this is your intent, then I'd use a Display state to control this.
