If I use projected view to make an isometric projection, the projection is in the wrong direction and doesn't change if I change the sheets type of projection.
If I add a new view with multiple views with the iso added, the view is created correctly.
Correct:
When using projected view and selecting the front plane and placing it at the bottom left:
Same with third angle:
Could this be a setting, or is it a bug?
