SW:2017
Is it possible to wrap text via a Custom Properties field in a Drawing (see attached pic)?
Right now we use 3 Property fields to populate each line (if needed). My ideal would be to type the Drawing Title via one Property field and depending on the length, the text would wrap to the next line.
Thanks.
-Art
I'm not sure I'm following what you're doing, but if instead of using the "Edit text" window, you'll double-click on the Note, then you can drag the Note box to set it to the desired width. If the text gets too long to fit it will go to a second line.
