I am 99% done drawing a drill press bracket and noticed there is this one awkward edge that still has a sharp and unrounded appearance. Whenever I try to fillet the edge itself it cuts away a lot of the material on the beam attached to it and throws off the measurements. Anyone ever finished this part before or have any idea how I should go about smoothing out those last edges? Or is it fine as it is and can go ahead and add it to my portfolio?
You might try editing some of the existing fillets and change the order in which edges to fillet are selected. If that doesn't work I'd suggest posting the file here. See How can I attach a file to a forum post? if you aren't familiar with the process.
