Hello
I have some trouble to recreate this piece :
but with the threading fonction I have the standard threads and I can't edit the standard threads
Do you think I should use another fonction ?
Hello
Thank you for your answers, I have didn't think to make it like this.
I have found another way, because after make this first piece I had another part to modelize, the base :
and to create this I used the helix/hairspring function to make the trajectory and then I made a sketch( the profile). Last , I used the sweep material removal function to select the trajectory and the sketch .
Use "Flex" command.
For top hole (if you have a problem) you can use Hole Wizard (or Cut Extrude and add "Cosmetic Thread"
