I can't access SOLIDWORKS PCB Services?
Can you access it through a webbrowser?
BRMarkus
how can i access it on the browser?
If you type this in the address field within the browser,
http://localhost:9780/
It should take you to the PCB Services Homepage where you can add accounts etc. Same login as you would use in SW PCB. If it doesn't work in the browser it's probably the connection that is broken somehow and not SW PCB.
Good day sir,
Still, I can't access the SOLIDWORKS PCB services thru the browser.
Maybe it's time reinstall PCB services? If it just were the ports being blocked by a firewall/antirivus I think it looks a bit different.
Could you reinstall (uninstall > reboot the machine > install) PCB Services as Markus suggested? See if that works.
Regards,
Andrii
BR
Markus
