Hi, I want to observe the displacement result of a nonlinear simulation. It's about the deformation of snap during assembly so I want to view it frame by frame.
I know solidworks can play the animation and can adjust the speed or the range of the frames/plot steps involved, but they are still too fast for me even under the lowest speed. I also know that there are two buttons under the colorbar in the result that I can use to go to previous/next frame, but it's not efficient and I cannot jump to the frame I want. (Like if I want to compare frames 3-6 and 15-18).
Is there any way I can view a specific frame I want easily, just like a slider? Or is it possible to export all the frames so that I can view whichever I want? Or any other possible solution will be appreciated. Thanks!
Taking this further, here's an efficient way to quickly jump to any plot step:
1. Pin the result plot PropertyManager to keep it visible
2. Select the 'Plot Step' field
3. Type desired step number
4. Press ENTER key TWICE
