I need to sketch this.
This is what I sketched but it's giving me a different value for Ixx. Anyone know what I did wrong?
I tried from top too but it still gave the wrong answer. I'm not sure what those two circles you highlighted indicate? Are you saying I should have a straight line there instead? I added a tangent relation between the top horizontal line and the spline and now I got a value much closer (5871107.68) but it looks wrong now, I'm pretty sure there shouldn't be a tangent relation in there.
David Lane wrote:
I don't care if it's from university or Elon Musk... It's still wrong. The task is to replicate the original sketch which cannot be done with the information given.
There isn't enough information to replicate this using a style spline either.
What about the original drawing? This is also information! You can use it as a blueprint. Will this help drag the handles?
Adeel please use snipping tool on the PDF to create the picture. Position the picture and then Scale the picture using one of the dimensions provided.
Sketch over the image as best you can.
2019 SOLIDWORKS Help - Inserting and Resizing Sketch Pictures
Yes, PDF is better for this. Its a vector format. But maybe this picture is as bitmap in pdf?
Anyway. Insert picture to sketch (I use this from your post) and drag spline handles
Different is from accuracy (need more "play" with handle) and I use cm as unit.
