i can get variables with the api ("IEdmEnumeratorVariable10"). But this is very slow. I need about 500ms to get a variable value.
So I want to use an sql query. I have found an Example here:
SQL query for multiple epdm variable values in a file
I have changed the Query a little. This is working fine and fast for the latest Version of the File:
with maxvar as (select documentid, variableid, configurationid, max(revisionno) revisionno from variablevalue group by documentid, variableid, configurationid)
select *
from
(select filename, v.variablename, vv.valuetext
from
documents d
inner join DocumentsInProjects dp on d.DocumentID = dp.DocumentID
inner join projects p on p.ProjectID = dp.ProjectID
inner join variablevalue vv on vv.DocumentID = d.DocumentID
inner join maxvar mv on mv.DocumentID = vv.DocumentID and mv.ConfigurationID = vv.ConfigurationID
and mv.VariableID = vv.VariableID and mv.revisionno = vv.RevisionNo
inner join Variable v on v.VariableID = vv.VariableID
inner join DocumentConfiguration dc on dc.ConfigurationID = vv.ConfigurationID
where filename LIKE 'TEST.SLDASM' and d.Deleted = 0 and dc.ConfigurationName = '@'
) a
PIVOT
(MAX(ValueText)
for variablename in ([Zeichnungsnummer], [Artikelnummer], [Bezeichnung1], [Bezeichnung2])
)pivot_table
Now I want to read the variables for an earlier version of the File. But how do I have to change the SQL query?
I can get all Versions with:
select *
from
(select filename, v.variablename, vv.valuetext, vv.RevisionNo --add vv.RevisionNo
from
documents d
and mv.VariableID = vv.VariableID -- and mv.revisionno = vv.RevisionNo
) a
PIVOT
(MAX(ValueText)
)pivot_table
I get a Table with (Example):
filename | RevisionNo | Zeichnungsnummer | Artikelnummer | Bezeichnung1 | Bezeichnung2 |
TEST.SLDASM | 1 | TEST | Test | Test | Test |
TEST.SLDASM | 2 | ||||
TEST.SLDASM | 3 | NULL | NULL | NULL | NULL |
TEST.SLDASM | 4 | NULL | NULL | Bez1 | Bez2 |
TEST.SLDASM | 5 | NULL | NULL | NULL | |
TEST.SLDASM | 6 | NULL | NULL | NULL | NULL |
If i only filter by RevisionNo i don´t get the right values.
See S-014197:
Be aware that only "unique" values are stored in the ‘VariableValue’ table . In other words, if there are no changes to a variable value over several file versions, only the most recent value is stored in the table.
But how can i get the right values for a specific Version?
Regards
Sascha
I see that I misunderstood what you were trying to do.
This query removes some of the extra complexity of my original query and finds what you were looking for.
The way it works is:
Notes:
