i have a number of parts such as screws and threaded rods
that are driven by design tables. These were all created pre 2009.
I can't edit them anymore, if i try to add a new configeration into the design table i get this error
"You cannot change the parent configuration of "M5x10mm threaded Rod" once it has been created.
Exiting design table without completing update."
"M5x10mm threaded Rod" is the first configeration in the table. I am not changing anything in that line.
Any ideas?
I'm running 2009 SP3.0
The design table is attached
Any ideas?
I was able to modify the excel files easily without any error. Can you upload the part along with the DT to look for the cause of error.
