Cut Weld Beads in Assemblies
Question asked by Cash Maitlen on Feb 8, 2020
Is it possible to extrude or revolve cut weld beads in an assembly?  The reason I am asking is because I tend to have welded assemblies that we machine after welding, so some portions of the welds are machined off.  The welds are currently not being affected by cuts in the assembly, so I am not able to create flat surfaces where the weld filled up the gap but then should be machined flat.  In my example pictures I show the weld bead before and after I add a circular extruded cut into the weld bead to remove material making a deeper counterbore.
