Is there a way to snap the associated or non associated paths between two parts that neutral positions have already changed.When i use "set as neutral properties" there is no problem with my current view but other views affected. Actually i want to my assembly parts exlpode after movement to the different direction.And i don't want to use Polyline.Because by Polyline command take long time.
Hi Serkan,
Are the components part of a sub-assembly? If so, move the components with Assembly Selection Mode and the components neutral position will behave how you want it to. This would be better than changing the neutral properties.
Regards,
Mike
