The scenario:
I have setup the Technology Database for my needs. (Tools, strategies, default settings etc.)
Now in the technology database all is perfect for me.
But if I open a part, and generate a operation plan, the default settings from before appears.
If I open the technology database, there are my settings. But in the actual part I must change all again by hand.
I can not find a setting to load all projct settings from the technology database.
Ok, I answer for myself.
Changing the default parameters is only for creating new strategies.
This are not the default settings for existing things.
To change the defaults of the existing strategies you must go to "Features & Operations"->Select the future you want ->Right side "Operation Parameters" and there click on the smal icon. Then opens a new window with the actual settings.
There you can overwrite them.
This problem occurs, why I´m not able to install Solidworks in my prefered language.
