DMDavid McCullough06/02/2020
I have been having a problem for a while with sketches not showing up when exporting flat patterns to a dxf, but today is the first time i have had a problem exporting the bend lines too. Does anyone have any suggestions or recommendations to check why this is not working? Screenshots of my process are attached.
This part has two sheet metal bodies. One exports the geometry and the bendlines fine, but does not export the sketch. the other body only exports the geometry and will not export the sketch or the bend lines.
UPDATE 2/13/20:
I have found that this problem is when you have more than one flat pattern body in the part. The first flat pattern in the part works perfectly fine. The rest of the flat patterns do not export the bend lines or sketches.
