I try to change third angle to first angle but the drawing doesn´t update. I make the change in sheet properties. What can I do?
I use Solidworks 2019.
Thanks.
Thanks.
To make the case more clear. I saw today that the problem is more like the drawing properties is changing opposite way. When I change projection to be first angle, in the drawing the type of projection seems to be in third angle. The original drawing is made in Solidworks 2018 and it has updated to 2019.
Has anyone face the problem? And how did you solve it?
In other case type of projection is working correctly.
Mira
