Ravindranath Johnson
One Assembly Affecting Another
Discussion created by Ravindranath Johnson on Feb 3, 2020
I'm trying to create an assembly of many different components from online for a robotics project. For two of the components, I've found that the order with which I load them affects how they load. For example, if I load the green one first, both appear as green, with the second one I loaded changing colors and having issues. The same happens in reverse. I've included screenshots of the issue. When I load the assembly, I've noticed that the model changes happen at the updating graphics step, before that the models look fine.
I've attached a file with both models and screenshots of the issue.
Thank you!
Solidworks 2019
Windows 10
