I am wondering,
is it possible to setup a multilevel BOM that looks like this,
the only thing i can think of is having different configs and showing the qty's for each configuration.
I am wondering,
Josh Brady wrote:
Yes, a BOM can be configured to show multiple different configurations and the qty of various components contained therein. Probably will look more like this though. Not sure the whole thing with the "x"s is possbile without some manual work.
If you really want those ROTARY TRANSDUCER ASSY entries in the BOM, you could place a dummy part into the assembly and give it a different part number in each assembly configuration. Then, instead of an "X" in the Qty column, that row would have a "1".
One workaround is to create a new column and use a Custom Property value and an IF Then equation for the column to place either the quantity or an "X" in the column based on the property value. It's a bit of work, but I think that portion could be handled "automatically"...But, that may have been what you meant by "manual work".
I think what'd help is if we had some files to work with. But that probably isn't possible because of IP reasons. David, can you upload an example? You can create a dummy asm from some generic parts and show us an excel table screenshot of what it should look like and I think we'd be more help.
