Hi, everybody!
I'm trying to write macros to add ordinate Dimension, but method SelectByRay does not working.
Solidworks record macro, but when run macro, it execute only AddOrdinateDimension
using SolidWorks.Interop.sldworks;
using SolidWorks.Interop.swconst;
using System.Runtime.InteropServices;
using System;
namespace Macro1.csproj
public partial class SolidWorksMacro
public void Main()
ModelDoc2 swDoc = null;
PartDoc swPart = null;
DrawingDoc swDrawing = null;
AssemblyDoc swAssembly = null;
bool boolstatus = false;
int longstatus = 0;
int longwarnings = 0;
swDoc = ((ModelDoc2)(swApp.ActiveDoc));
ModelView myModelView = null;
myModelView = ((ModelView)(swDoc.ActiveView));
myModelView.FrameState = ((int)(swWindowState_e.swWindowMaximized));
swDrawing = ((DrawingDoc)(swDoc));
boolstatus = swDrawing.ActivateView("Front");
boolstatus = swDrawing.ActivateSheet("Лист1");
boolstatus = swDrawing.ActivateView("Слева");
boolstatus = swDoc.Extension.SelectByID2("Point1@Sketch2@Left_2513.0002-XX_2450.00000437-XX_1-6@Слева", "EXTSKETCHPOINT", 0, 0, 0, false, 0, null, 0);
// Vertical Ordinate Dimension
longwarnings = swDoc.Extension.AddOrdinateDimension(2, 0.3686965293215061501, 0.1428529440913848814, 0);
swDoc.ClearSelection2(true);
boolstatus = swDoc.Extension.SelectByRay(0.3792170666658048472, 0.1486479905188686779, -2999.715999999999894, 0, 0, -1, 6.611797961296777464e-05, 1, false, 0, 0);
boolstatus = swDoc.Extension.SelectByRay(0.3796391784630119837, 0.1580754699585562029, -2999.715999999999894, 0, 0, -1, 0.000589514547664962826, 1, false, 0, 0);
boolstatus = swDoc.Extension.SelectByRay(0.3791190185680134439, 0.1715996272285171265, -2999.715999999999894, 0, 0, -1, 0.000589514547664962826, 1, false, 0, 0);
boolstatus = swDoc.Extension.SelectByRay(0.3792924051996796608, 0.1863374909201412077, -2999.715999999999894, 0, 0, -1, 0.000589514547664962826, 1, false, 0, 0);
boolstatus = swDoc.Extension.SelectByRay(0.3792924051996796608, 0.1953535957667817957, -2999.715999999999894, 0, 0, -1, 0.000589514547664962826, 1, false, 0, 0);
swDoc.SetPickMode();
/// <summary>
/// The SldWorks swApp variable is pre-assigned for you.
/// </summary>
public SldWorks swApp;
SelectByRay is not reliable. Find your edges with GetVisibleEntities instead.
2016 SOLIDWORKS API Help - Get All Edges in Visible Component in Drawing View Example (VBA)
Then get the coordinates of each of their extremities (or arc center), to differentiate between them.
2016 SOLIDWORKS API Help - GetStartVertex Method (IEdge)
