We have 2 end conditions in hole feature as shown in image:
when I callout hole in drawings, there is no mention about the end condition in drawing note. It shows 15 in either of the option.
Except creating the section view, what is the best practice you implement to communicate hole depth is upto tip or shoulder?
Refer to ASME/ANSI Y14.5 standard. Drilled holes should always be designated to the 'shoulder' depth UNLESS your industry specifies something unique for some reason. Your example indicates a thru hole condition by the looks. In that case, obviously, depth is irrelevant.
