I've watched a ton of MBD, DimXpert videos over the years from respected sources such as Trimech, GoEngineer, SolidWorks, etc. and they all have one thing in common: They present the practice of creating 3D annotations as
(re)creating what one would expect on a typical 2D drawing, i.e. a fully dimensioned part. In this day and age when most companies have been exchanging 3D models for many years (and therefore have the ability to query the model), it confounds me a little to see this.
Assume you have embraced (or at least bro-hugged ;-) MBD/3D annotations, you are faced with a choice: fully dimension the model and generate a PDF or drawing, or minimally dimension, relying on established standards (both industry-wide and company-specific) in a way that clearly defines those characteristics of the model that are not covered and defined by other standards. I have a list of requirements to support minimal dims (none of this is radical or even innovative necessarily, just my thoughts:
1. Establish default dimensional tolerances
2. Establish Profile of Surface default value
3. Establish default dimension place values
4. Define primary datums [A, B, C]
5. State clearly that the model is the truth!
As an example, consider the following (admittedly simple) part, fully dimensioned using DimXpert:
If I apply the proper standards, such as this:
ALL DIMENSIONS ARE INCHES UNLESS OTHERWISE SPECIFIED
DIMENSIONING AND TOLERANCING PER ASME Y14.5 - 2009
FEATURES WITH NO GEOMETRIC TOLERANCE INDICATED SHALL HAVE A PROFILE TOLERANCE ZONE OF .010 APPLIED
FEATURES WITH NO LOCATIONAL TOLERANCE INDICATED SHALL HAVE A TOLERANCE OF +/- .020 APPLIED WITH RESPECT TO THE PRIMARY DATUMS [A, B, C] OF THE 3D SOLID MODEL
FEATURES WITH EXPLICIT ANNOTATIONS SHALL HAVE THE FOLLOWING TOLERANCES UNLESS OTHERWISE SPECIFIED:
.XX = +/- .01
.XXX = +/- .005
ANGLES = +/- 1 Deg.
The result, I submit, would be this:
By the way, the output media on this is irrelevant; it could be a 2D drawing, or a 3D PDF, or just the model.
So... is this viable as an approach to MBD/3D annotations? I'd like to get feedback on this from everyone, but especially from those on the manufacturing end.
Sorry for the long post, but I wanted to lay the discussion out clearly.
You're absolutely right that the fully dimensioned approach is overkill. I suspect that they provide those examples for a couple of possible reasons. One might be not trying to introduce too many methodologies at once (MBD and Reduced Dim. Drawings). I've also seen VAR Application Engineers who have been out of the industry for a while and are simply SW (or even specific add-in) power-users.
Why even include the 1.50 +/-.02 for the slot? It doesn't add anything that your note 3 or 4 doesn't.
Our company for a long time now, on traditional 2D drawings, have produced reduced dimension drawings similar to how you've described. This works if your manufacturer can digest either the 2D data (DXF or otherwise for flat objects) or the 3D data itself. Why dimension every single facet of a part when no tolerance other than a general tolerance suffices? The CAM software they're using to program will digest all of that information automatically and machining tolerances these days are fantastic. You need to provide them the appropriate information to make the part, and that's it. Sure, we have parts that I know will either be cut by hand and couple holes drilled or simply setup on an older mill that will get the full dimension treatment but that's <5% of parts. Maybe even <1%.
We have for a while and are currently investigating MBD again. I perused your other topic; I'll chime in there when I have more free time. This gets you so close to MBD that it's an interesting conversation to justify the jump to MBD.
