In SW Electrical, I can change the root of the components in the classifications manager. But there is a manner to retag all the components in my project with this modification (Ex: Change for all relays the root K by CR)?
I tried to use "Renumber Marks" with all available options and nothing change.
Emmanuel
Once the Root is chosen, that Root remains with the component until you manually adjust it. In theory, you can take a different approach, but it is rather advanced to Export to Excel a table of your project components, adjust the Root, and then import from Excel with the Root changed on those select components. It all depends, if you're wanting to update 5 components, just do that by going to the component properties and changing it from the Root drop down, if you need to update 100, you can explore the export/import option.
