I'm unable to flatten this entire sheet metal. I cannot seem to fix this issue? Attached is the part. This is the fattened configuration and there are four bent features that cannot flattened. I need to flatten these as well but I cannot. Please help me fix this.
This is the folded configuration
When you can't figure out where, roll back and test.
Before this extrude, I added an unfold and it worked.
Adding an unfold after the extrude, and the unfold can't:
The extrude is the problem child, which isn't too surprising since it's a non-sheet metal tool in the middle of a sheet metal part.
Look into a tab instead or better yet, create this entire side as one flange, unfold both long bends, extrude cut the rectangular opening and refold it.
Kevin
