I have tried every .dxf macro I could come up with, and my process is to name all my sheets the file (part name) and make a single .dxf of each sheet. I keep getting (4) copies of the .dxf of each sheet for some reason and I have no clue how to control this....The macro also puts a "00" in front of all the file names.
I am using Deepak's code here
Dim swSheet As SldWorks.Sheet
Dim vSheetNameArr As Variant
Dim vSheetName As Variant
Dim bRet As Boolean
Dim swExportPDFData As SldWorks.ExportPdfData
Dim lErrors As Long
Dim lWarnings As Long
Set swModel = swApp.ActiveDoc
' Is document active?
If swModel Is Nothing Then
swApp.SendMsgToUser2 "A Drawing document must be active.", swMbWarning, swMbOk
Exit Sub
' Is it a Drawing document?
If swModel.GetType <> swDocDRAWING Then
Exit Sub
Set swDraw = swModel
Set swSheet = swDraw.GetCurrentSheet
vSheetNameArr = swDraw.GetSheetNames
For Each vSheetName In vSheetNameArr
bRet = swDraw.ActivateSheet(vSheetName): Debug.Assert bRet
swDraw.ViewZoomtofit2
Set swExportPDFData = swApp.GetExportFileData(1)
swExportPDFData.SetSheets swExportData_ExportSpecifiedSheets, vSheetName
swModel.Extension.SaveAs vSheetName + ".dxf", 0, 0, swExportPDFData, lErrors, lWarnings
Next vSheetName
