I'm making an inseparable assembly. Holes are being added at the assembly level. However, the datum hole keeps changing it's measuring location when I switch configurations (see attached pics). The pics show config 1 where the holes should be. When I correct the location of the holes in config 2, config 1 goes haywire in the opposite direction that 2 did originally. I tried making these with the Hole Wizard, then with the cut feature and it happens both ways. Any ideas on why this is happening?
My first question would be what are you placing dimensions from to locate the holes?
