Select all suppressed components in Assembly API
Question asked by Eric Schwieterman on Jan 17, 2020
Latest reply on Feb 7, 2020 by Vladimir Urazhdin
Trying to select all components in Assembly tree that are suppressed.  I can't get it to recognize the suppression.  My suppressed variable always shows false regardless if the component is suppressed or not.  Here is my code.  What am I doing wrong?
Dim fileerror As Long
Dim filewarning As Long
Dim swFeatMgr As SldWorks.FeatureManager
Dim nErrors As Long
Dim nWarnings As Long
Dim swFeat As SldWorks.Feature
Dim boolstatus As Boolean
Dim swModelDocExt As ModelDocExtension
Dim featName As String
Dim vConfNameArr As Variant
Dim vSuppStateArr As Variant
Dim suppressed As Boolean
Set swModel = swApp.ActiveDoc
Set swFeat = swModel.FirstFeature
Do Until swFeat.GetTypeName2 = "Reference"
Set swFeat = swFeat.GetNextFeature 'get next component in the tree
Loop
Do While swFeat.GetTypeName2 <> "MateGroup"
If swFeat.GetTypeName2 = "Reference" Then 'is feature a sw file
Debug.Print swFeat.Name
vConfNameArr = swModel.GetConfigurationNames
vSuppStateArr = swFeat.IsSuppressed2(swThisConfiguration, vConfNameArr)
suppressed = vSuppStateArr(0)
Debug.Print vSuppStateArr(0)
If suppressed = True Then
swFeat.Select (True) ' select
'Debug.Print swFeat.isSuppressed
Else
Loop
Thanks for your help
