I have a doubt about the two syntax, just $PRP@Weight and
$SW-MASS?
Another question is: is it possible for DT to calculate mass for several configs parts at the same time. my means are the DT can show me the results for several configs at the same time after i input several dimensionals. now i have to use mass properties to assign each config to only get the result of that config.
Wenyang,
I believe this is in the Help files and I belive that is the reason why you are not getting any responses. Do a little research and then ask a more pointed question.
Basically:
$Prp@WEIGHT is a User defined custom or configuration specific file property.
$SW-MASS is a system defined property.
