Hi all, in need of some urgent help here as im going out of my mind!
I have tried every setting imaginable but still having now luck.
Basically I have created a 3 sheet drawing in Solidworks and go to 'save as' DXF,
however when this is saved, I open the DXF and it looks like below... all 3 sheets are different to (Sometimes sheet 1 is the only sheet with any issues...
Above is how the drawing looks that I have been working on
Above shows the saved DXF when opened
Any help is much appreciated as Im running out of time for this job and cant figure the problem out!
Thank you,
Dylan
UPDATE
I tried to export this drawing file via #TASK and it worked.. So i assume there is some issue with my export settings but I still cant figure out which ones
Check this setting and make sure it is unchecked
