Best practice for cutting a wooden plate
Question asked by Dan D. on Jan 14, 2020
Latest reply on Jan 14, 2020 by Dan D.
I plan to build several cabinets using 240x120x2cm wooden plates.
The cabinet will be made from several rectangle plates (like most normal cabinets…)
I would like use the 240x120 plate as efficiently as possible.
For simplicity let’s assume use a box, with 4 plates for the sides and 1 bot the bottom.
2 sides 60x40
2 sides 56x40 (removing the 2cm plate thickness on each side)
1 base 60x60
I was thinking of creating the box is SW from those 5 parts and afterwards places those 5 parts of a 240x120 bounding box with 5mm gap (for the saw). This will allow me to produce an effacing cutting scheme.
I would demand that I save each plate externally, in this case I will use 1 part with multiple configurations.
What I would like to know if this is the ‘right’ or easiest way, or, is there a better way.
Again, my final goal in this is to present an efficient cutting scheme for the 2540x120 plate.
