CCCraig Cloud14/01/2020
When using the hole wizard to create an NPT thread, the model will create the taper that is produced by the thread cutting.  Is there a way to turn this off?  Even if I set the feature to cosmetic it still creates a taper, albeit smaller in diameter.  I ask because when I send a part to a machine shop that makes the parts off the model, they want to machine the part with the taper and then tap.  To get a properly made part, I have to model only a drilled hole and then manually call out the NPT thread.  This makes the model technically wrong because the threaded feature doesn't exist in the model.
