Making a simple plate cap (part) for a 12.75" OD pipe. I've tried with projections, section cuts, curves, skewed planes, etc to make a part with the elliptical shape but always run into some problem such as a sketch that won't project on the skewed plane but reverts back to a perpendicular plane. Or "items can not be converted" or something.
This seems like it would be childishly simple, but it is killing me.
See attached, I only want to make caps for the ends that fit the skewed cut.
1, Make sketch on cuting plane
2. In Scetch Use a cut edge - Convert Entities (inside or outside)
3. Add Extrude (if you need you can use pipe axis as extrude direction)
4. Make a coffee and smile
B.R.
