Change Path on save to PDF VBA Macro
Question asked by Michael Ortíz on Jan 9, 2020
Latest reply on Jan 20, 2020 by Michael Ortíz
I am trying to use a pre-made macro created by Deepak Gupta  to save my multi sheet drawing as individual pdf files.  The macro is working great except that I need to customize the path where the pdf files are being saved.  I don't have much experience in writing macros and have been digging around the forums and online trying to uncover which part of this macro is designating the "save to" location.  I would like to assign my own location but don't see how.  Below is the code from the macro.  Thanks in advance for your help.
Regards,
Mike
'Export Drawing Sheets As PDF.swp ------------- 10/19/12
'Description: Macro to export Drawing Sheets As PDF with sheet name as file name.
'Precondition: Any active drawing file
'Postconditions: PDF file in the same location as drawing file.
' Please back up your data before use and USE AT OWN RISK
' This macro is provided as is.  No claims, support, refund, safety net, or
' warranties are expressed or implied.  By using this macro and/or its code in
' any way whatsoever, the user and any entities which the user represents,
' agree to hold the authors free of any and all liability.  Free distribution
' and use of this code in other free works is welcome.  If any portion of
' this code is used in other works, credit to the authors must be placed in
' that work within a user viewable location (e.g., macro header).  All other
' forms of distribution (i.e., not free, fee for delivery, etc) are prohibited
' without the expressed written consent by the authors.  Use at your own risk!
' Written by: Deepak Gupta (http://gupta9665.wordpress.com/)
Dim swApp                   As SldWorks.SldWorks
Dim swModel                 As SldWorks.ModelDoc2
Dim swDraw                  As SldWorks.DrawingDoc
Dim swSheet                 As SldWorks.Sheet
Dim vSheetNameArr           As Variant
Dim vSheetName              As Variant
Dim bRet                    As Boolean
Dim swExportPDFData         As SldWorks.ExportPdfData
Dim lErrors                 As Long
Dim lWarnings               As Long
Set swModel = swApp.ActiveDoc
' Is document active?
If swModel Is Nothing Then
    swApp.SendMsgToUser2 "A Drawing document must be active.", swMbWarning, swMbOk
    Exit Sub
' Is it a Drawing document?
If swModel.GetType <> swDocDRAWING Then
    Exit Sub
Set swDraw = swModel
Set swSheet = swDraw.GetCurrentSheet
vSheetNameArr = swDraw.GetSheetNames
For Each vSheetName In vSheetNameArr
bRet = swDraw.ActivateSheet(vSheetName): Debug.Assert bRet
swDraw.ViewZoomtofit2
Set swExportPDFData = swApp.GetExportFileData(1)
swExportPDFData.SetSheets swExportData_ExportSpecifiedSheets, vSheetName
swModel.Extension.SaveAs vSheetName + ".PDF", 0, 0, swExportPDFData, lErrors, lWarnings
Next vSheetName
