Richard Kendrew
How to get Macro to check an assembly has fully loaded before proceeding?
Discussion created by Richard Kendrew on Jan 9, 2020
Latest reply on Jan 11, 2020 by Deepak Gupta
I have the following code from this link. It's used to run macro when the file is opened.
Run VBA macro on model load using macro feature and SOLIDWORKS API
This problem is that its running the Sub 'OnModelLoad' before the model is fully loaded.
The 'OnModelLoad' sub opens a form with a list of all configurations, but as this runs before the model has finished loading it is kicking up a macro error response.
Anyway of fixing this?
Dim swApp As Object
Const EMBED_MACRO_FEATURE As Boolean = True
Const BASE_NAME As String = "ModelLoadWatcher"
Dim HandledModels As Collection
    Set swModel = swApp.ActiveDoc
    Dim UserConfirmEmbed As Integer
    If Not swModel Is Nothing Then
        'USER PROCEED CONFIRMATION REQUEST
        UserConfirmEmbed = MsgBox("Are you ready to Embed Macro?", vbYesNo + vbQuestion, "Confirmation Request")
        If UserConfirmEmbed = vbYes Then
        Dim curMacroPath As String
        curMacroPath = swApp.GetCurrentMacroPathName
        Dim vMethods(8) As String
        Dim moduleName As String
        GetMacroEntryPoint swApp, curMacroPath, moduleName, ""
        vMethods(0) = curMacroPath: vMethods(1) = moduleName: vMethods(2) = "swmRebuild"
        vMethods(3) = curMacroPath: vMethods(4) = moduleName: vMethods(5) = "swmEditDefinition"
        vMethods(6) = curMacroPath: vMethods(7) = moduleName: vMethods(8) = "swmSecurity"
        Dim opts As swMacroFeatureOptions_e
        If EMBED_MACRO_FEATURE Then
            opts = swMacroFeatureOptions_e.swMacroFeatureEmbedMacroFile
        Else
            opts = swMacroFeatureOptions_e.swMacroFeatureByDefault
        Dim swFeat As SldWorks.Feature
        Set swFeat = swModel.FeatureManager.InsertMacroFeature3(BASE_NAME, "", vMethods, _
            Empty, Empty, Empty, Empty, Empty, Empty, _
            Empty, opts)
        If swFeat Is Nothing Then
            MsgBox "Failed to create model load watcher"
        'USER CONFIRMATION REQUEST CONTINUED...
        Else
            MsgBox "Macro Embedding Skipped"
                OnModelLoad swModel
    Else
        MsgBox "Please open model"
Sub GetMacroEntryPoint(app As SldWorks.SldWorks, macroPath As String, ByRef moduleName As String, ByRef procName As String)
    Dim vMethods As Variant
    vMethods = app.GetMacroMethods(macroPath, swMacroMethods_e.swMethodsWithoutArguments)
    Dim i As Integer
    If Not IsEmpty(vMethods) Then
        For i = 0 To UBound(vMethods)
            Dim vData As Variant
            vData = Split(vMethods(i), ".")
            If i = 0 Or LCase(vData(1)) = "main" Then
                moduleName = vData(0)
                procName = vData(1)
        Next
Function swmRebuild(varApp As Variant, varDoc As Variant, varFeat As Variant) As Variant
    swmRebuild = True
End Function
Function swmEditDefinition(varApp As Variant, varDoc As Variant, varFeat As Variant) As Variant
    swmEditDefinition = True
End Function
Function swmSecurity(varApp As Variant, varDoc As Variant, varFeat As Variant) As Variant
    Set swFeat = varFeat
    If HandledModels Is Nothing Then
        Set HandledModels = New Collection
    Set swModel = varDoc
    If Not CollectionContains(HandledModels, swModel) Then
        HandledModels.Add swModel
        Set swApp = varApp
        ClearCache swApp
    OnModelLoad swModel
    swmSecurity = SwConst.swMacroFeatureSecurityOptions_e.swMacroFeatureSecurityByDefault
End Function
Sub ClearCache(app As SldWorks.SldWorks)
    If Not HandledModels Is Nothing Then
        Dim vDocs As Variant
        vDocs = app.GetDocuments
        If Not IsEmpty(vDocs) Then
            Dim i As Integer
            For i = HandledModels.Count To 1 Step -1
                Set swModel = HandledModels(i)
                If Not ArrayContains(vDocs, swModel) Then
                    HandledModels.Remove i
            Next
Function CollectionContains(coll As Collection, model As SldWorks.ModelDoc2) As Boolean
    Dim i As Integer
    For i = 1 To coll.Count()
        If coll(i) Is model Then
            CollectionContains = True
            Exit Function
    Next
    CollectionContains = False
End Function
Function ArrayContains(arr As Variant, model As SldWorks.ModelDoc2) As Boolean
    Dim i As Integer
    If Not IsEmpty(arr) Then
        For i = 0 To UBound(arr)
            Dim thisModel As SldWorks.ModelDoc2
            Set thisModel = arr(i)
            If thisModel Is model Then
                ArrayContains = True
                Exit Function
        Next
    ArrayContains = False
End Function
Sub OnModelLoad(model As SldWorks.ModelDoc2)
    HandlerModule.HandlerMain model
