Is there a way to invert colours in drawings only in editing mode that does not affect the same is printed. I know that you can do in change colours in Options > Colors.
As far as i know, there is no quick/easy way.
Like what you said, you can change the colours under System Options > Colors, but this involved quite some work as you had to change all the colour involved in drawing, text. After changing the color, you can save the color scheme. You will most probably need to change back the color scheme to default when you want to print the drawing. Other issue that i can foresee is you might have some issue with table as the color of the border depend on the layer applied.
Below is something i learnt from Matt Lombard-- Mastering Solidworks
