What is the point of lofted bends if you aren't able to add
flanges and other sheet metal features to it. I have a lofted bend
that has a straight profile and and a curved profile. After I loft
it, I am unable to add any other sheet metal features to the lofted
bend. I get the following when I try to pick an edge to create a
flange: "Selected edge is not on planar faces".
Thank You.
Thank You.
I did update your file slightly hoping that it would work as a sheet metal part should but no luck. What I did was add two more points to the lower sketch as lofts like to have the same number of points in each sketch.
Not sure if your VAR could help any but they may be able to explain why..
