I just upgraded to SW2019, SP5. Today is my first real use of it and I've already encountered a serious bug that I haven't seen before. There is a new checkbox in the dimension manager panel called Link Precisions with Model. When I check this box, all of the tolerances get changed to +.035/-0. If the dimension doesn't have a tolerance and I change the tolerance to Limit, I get the same +.035/-0 limits. To make matters worse, not only is the drawing wrong, ensuring that the part will be machined incorrectly, but it also drives the incorrect tolerance down to the model.
Is this a known bug or have I once again achieved something unique? Is there a solution?
Do you have a screenshot of it or a drw. maybe?
